1994 Cadillac DeVille Brake Vibration
TED G
I have a 94 Cad sedan deville with 70000 miles. The engine size is 4.9L. The brakes vibrate at the end of higher speed braking. The brake pads are new, the disks were turned for the first time and are on the high side. The disks are flat ie not warped, and the slides are clean with light lube on them.The front end, likage etc are tight. No signs of alignment problems. Any ideas?
Sep 19, 2007 at 10:00 PM
SERVICE WRITER
  • 9,123 POSTS
[quote:9f5f619a3d="ted g"]I. The brakes vibrate at the end of higher speed braking. The disks are flat ie not warped.[/quote:9f5f619a3d]
Did this start after the brake job or was it present beforehand? 4-wheel disc?
What is likley happening is the rotors are unable to handle the heat from the friction caused by the braking action at additional force. As the heat up, they warp, as they cool the return to flat.
Sep 19, 2007 at 10:04 PM
BUZZSAW
  • 1,198 POSTS
[quote:aec7ce8552="ted g"]I have a 94 Cad sedan deville with 70000 miles. The engine size is 4.9L. The brakes vibrate at the end of higher speed braking. The brake pads are new, the disks were turned for the first time and are on the high side. The disks are flat ie not warped, and the slides are clean with light lube on them.The front end, likage etc are tight. No signs of alignment problems. Any ideas?[/quote:aec7ce8552]
sorry who ever turned your rotors did a bad job, and if you stuck the old pads back on a new rotor turn you probally warped them again. did you do all 4 rotors, push the emergency brake down while driving and see if it is in the rear rotors while holding the release lever
Sep 21, 2007 at 2:51 PM
Suggested Repair
Replace the turned rotors rather than relying on another cut; they may be too thin or poorly machined and can heat-warp during higher-speed stops even if they measure flat when cool. Isolate front versus rear by carefully applying the parking brake while moving (hold the release) to see if the vibration is in the rear rotors. Fit quality pads with the new rotors and do not reuse old pads on freshly cut rotors.
Conversation Summary
The owner of a 1994 Cadillac DeVille with a 4.9L engine reports brake vibration at the end of higher-speed stops after new pads and a first rotor turn. The rotors measure flat and thick, the slides are clean, and the front end is tight. Experts say the rotors are likely warping from heat or were poorly machined, and recommend isolating front versus rear and replacing the affected rotors.
