I HAVE A 99 CADILLAC DEVILLE I RECENTLY HAD A MECHANIC PERFORM A PROCEDURE WITH HEAL A SEAL FOR A HEAD GASKET ISSUE EVERTHING SEEMED TO BE OK THE CHECK ENGINE LIGHT IS STAYING OFF I HAD A CYLINDER MISFIRE, I HAD COOLANT IN THAT #1 CYLINDER CAR STILL RUN SMOTHLY NO MISS BUT IT OVERHEATS WHEN DRIVING IT AN AFTER DRIVING IT THE RADIATOR DOES NOT FEEL HOT IN BETWEEN THE TWO ELECTRIC FANS SHOULD IT BE HOT? ALSO THE MECHANIC THAT WORKED ON MY CAR SAYS THAT HE THINKS IT IS AN AIR POCKET CAN U PLEASE HELP I DONT KNOW WHAT ELSE TO DO THE CAR HAS 107,000 MILES ON IT 4.6L NORTHSTAR
Oct 20, 2007 at 4:46 PM
