2006 Cadillac Deville how to change front turn signal bulb
64,000 MILES • V8 • FWD • AUTOMATIC
MWHITE99
how do i get to turn signal bulb ? owners manual said to to take to dealer for all bulb replacements !
Dec 14, 2008 at 9:14 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Could you please specify wether this is a front or rear turn signal, as well as which side the signal bulb is on?
Dec 14, 2008 at 9:37 AM
MWHITE99
Hello- the cadilac is a 2006 DTS , the left front turn signal bulb is burned out , I found two bolts in top of light assm. are there more bolts or does the assm. pull up ?
Thanks in advance
Dec 14, 2008 at 11:50 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Thanks for that info. There will be one more bolt before you can pull it out and disconnect wiring.
https://images.2carpros.com/forum/automotive_pictures/261618_Noname2_17.jpg
HID REMOVAL:
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_48.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_47.jpg
Dec 14, 2008 at 12:01 PM
