2005 Cadillac Deville cold air
47,000 MILES • V8 • 2WD • AUTOMATIC
HANEYRB55
I have a 2005 deville with dual air/heat controls when i turn on the air the blower blows air from both sides but the drivers side is cool to warm and the passenger side will freeze you out when the heat is turned on both sides are fine. What is the problem and how can i correct it.
May 14, 2008 at 1:25 AM
BUZZSAW
  • 1,198 POSTS
[quote:c1cc19a23c="haneyrb55"]Air Conditioning problem
2005 Cadillac Deville V8 Two Wheel Drive Automatic 47000 miles
I have a 2005 deville with dual air/heat controls when i turn on the air the blower blows air from both sides but the drivers side is cool to warm and the passenger side will freeze you out when the heat is turned on both sides are fine. What is the problem and how can i correct it.[/quote:c1cc19a23c]
there is an air mode door actuator down by your gas petel may be the prob
the car is still under warranty, 5 yrs 50k
May 14, 2008 at 5:34 PM
