1997 Cadillac Deville hot and cold
120,000 MILES • V8 • FWD • AUTOMATIC
JARVISMJOHNSON
I have a '97 deville that the a/c blows cold on the pass. side but blows hot on the drivers side and rear. The kids are getting sticky in back! please help. Thanx J. Johnson
Apr 21, 2008 at 3:15 AM
BUZZSAW
  • 1,198 POSTS
[quote:da2ed749f3="jarvismjohnson"]Air Conditioning problem
1997 Cadillac Deville V8 Front Wheel Drive Automatic 120000 miles
I have a '97 deville that the a/c blows cold on the pass. side but blows hot on the drivers side and rear. The kids are getting sticky in back! please help. Thanx J. Johnson[/quote:da2ed749f3]
do you have duel climate control? one for driver and one for passenger
Apr 21, 2008 at 3:40 AM
JARVISMJOHNSON
yes, it does have an adjustment knob on the pass. door console, but it still blows cold no matter where that dial is set. driver side still hot no matter where pass. dial is set
Apr 21, 2008 at 4:09 AM
BUZZSAW
  • 1,198 POSTS
[quote:d3cc8c9386="jarvismjohnson"]yes, it does have an adjustment knob on the pass. door console, but it still blows cold no matter where that dial is set. driver side still hot no matter where pass. dial is set[/quote:d3cc8c9386]
ck the freon level, you need a guage for AC. it runs about 28 to 30 psi on the guage, if its lower than that its low and needs a recharge, if its higher its got problems like a blockage, probally the orfice tube
you can also pull the codes for me to see if there is any AC codes in it
push off and warmer on the heater controls at the same time, with the key in the on position, look in the message center on the Insterment panel for the codes and post them here
Apr 21, 2008 at 9:17 AM
JARVISMJOHNSON
Thank You all for your input, I found the blend door, or zone control actuator whichever you call it was stuck. I gave it a little twist with a pliers, and now it works fine. Yeah kids will be happier. Thank You for your time.
Apr 21, 2008 at 12:47 PM
