2005 Cadillac Deville Air Bag Switch
SJWALCK
Electrical problem
2005 Cadillac Deville V8 Two Wheel Drive Automatic
A Friend of mine took his Cadillac to the dealership and they said that it has a bad air bag switch.
I have looked all over on-line and can't seem to find a replacement... Is this the switch to disable the pass-side air bag or is it a seat or seatbelt sensor, if so, where is it located and where I can purchase replacement parts for it..
Thank You,
Steve Walck
Jun 25, 2010 at 8:02 AM
FACTORYJACK
  • 4,159 POSTS
They need to be more descriptive, there is no switch in the system. Here is a list of the components in the system. It should not have a switch to disable the passenger side airbag.
Jun 25, 2010 at 3:03 PM
SJWALCK
Where is the list ???
I didn't see it...
Jun 25, 2010 at 8:49 PM
FACTORYJACK
  • 4,159 POSTS
I am sorry, I copied it but neglected to paste it.
---------------------------------------------------------------------The frontal SIR system consists of the following components:
• AIR BAG indicator located in the instrument panel cluster (IPC)
• Inflatable restraint front end sensor
• Inflatable restraint I/P module
• Inflatable restraint sensing and diagnostic module (SDM)
• Inflatable restraint steering wheel module
• Inflatable restraint steering wheel module coil
• Inflatable restraint seat belt pretensioners
• Inflatable restraint wiring harnesses
• Steering wheel and column
Jun 26, 2010 at 3:10 AM
