2004 Cadillac Deville Service Engine Soon light
PMASPKS
  • 7 POSTS
Transmission problem
2004 Cadillac Deville V8 Front Wheel Drive Automatic
I have replaced all sensors, EG Valve, and cat converter. [$650] One and only code left is for some very slight slippage in the transmission torque converter. Thats a $2,000 repair just to get this car through Oregons stupid DEQ test. Is there some way to turn that dumb light off? I'd cut the wire but I simply can't find it.
Sep 7, 2010 at 11:20 AM
FACTORYJACK
  • 4,159 POSTS
If you were to cut a wire, it would not necessarily solve the problem. You could clear the code, and hope it doesn't reset for a while, the problem is it also resets the I/M readiness status'.
Sep 8, 2010 at 3:42 PM
