2004 Cadillac Deville misfire
95,000 MILES • V8 • FWD • AUTOMATIC
JOKER_505
i have an 04 deville with multiple misfires. I have replaced the plugs and coil packs, and it got a little better but it still misfires enough not to pass emissions. Any idea's?
Apr 28, 2009 at 2:29 PM
FACTORYJACK
  • 4,159 POSTS
If you can determine which cylinders, swap some secondary parts. If the misfires are on 1 bank, swap the coils. Or change plugs of affected cylinders. If the fault stays with the cylinder, you could have dirty/sticking injectors, water in the fuel, or a mechanical problem. A compression and leakdown test would be advised at that point.
Apr 28, 2009 at 3:29 PM
