2004 Cadillac Deville Fuel gauge reading incorrectly someti
2004 CADILLAC DEVILLE
74,000 MILES • V8 • 2WD • AUTOMATIC
WALDO_WOLF
Our fuel gauge sometimes reads "Full" all the time as the fuel is being used. I put it 18 gallons of gas into a "full" tank recently. However sometimes it works properly too. My Cadillac dealer believes that the problem is the sensor inside the gas tank and says it will be necessary to remove the gas tank to replace this sensor. I was under the impression that there was an access port so it could be replaced without removing the entire tank. Is it necessary to totally remove the gas tank to replace this sensor?
Jul 21, 2010 at 5:18 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Dealer right fuel tank must be removed access door good idea but only seen that on VolVo and Saab and one model VW.
Hope this helps
Thanks for donate
Jul 21, 2010 at 7:53 AM
