2004 Cadillac Deville dtc-co660 automatic level control sy
56,000 MILES • V8 • FWD • AUTOMATIC
MCWEENS
at a loss with the alc system. have a dtc co660 code tells me to repair the coil side feed circuit of the exhaust solenoid. did a continuity check on the coil side feed wire and its fine. replaced the (rim)-rear integration module ,replaced the level control switch, Can't figure this one out. the only way i can get the compressor to run for the shocks is to stick a jumper wire in the relay sockets in the fuse box. if this is a wiring issue i could use a wiring diagram of that system. the only other thing that i can think of is, since the compressor works it must be the exhaust solenoid itself. but this requires buying a complete compressor system and thats not cheap. any ideas would help, thank you.
Sep 6, 2009 at 7:37 AM
FACTORYJACK
  • 4,159 POSTS
If you clear the code, does it reset immediately. More than likely it is the exhaust solenoid, that is primarily what fails.
Sep 6, 2009 at 3:34 PM
