2004 Cadillac Deville Breaking makes it shake
68,000 MILES • V8 • 2WD • AUTOMATIC
IRASCADDY
When ever I break on the freeway the front end shakes just a little. I recently changed the break pads and rooters but the problem constant.
Feb 20, 2009 at 1:53 AM
FACTORYJACK
  • 4,159 POSTS
It sounds like brake pulsation due to warped rotors. This could also be caused by the rear brakes. I'm assuming that the brake job was done front only? It can also be emphasized by loose tie rod ends, which are steering components.
Feb 20, 2009 at 2:05 PM
