blower will not blow, but it will still warm up. what could be the problem
Nov 18, 2009 at 2:23 AM
FACTORYJACK
✓Experienced Mechanic
I would suspect a blower motor. Remove the rh lower instrument panel insulator, check for power and ground at the blower motor connector with the system on. Tap on the blower housing with a screwdriver handle or something, it may operate.
