2003 Cadillac Deville Windsheild Washer Pump
60,000 MILES • V8 • 2WD • AUTOMATIC
RLGOURLEY
I can hear the windshield washer pump motor running, but it is not spaying windshield washer fluid on the windsheild. I checked the hoses and they are not stopped up. Can anyone tell me what else I mgiht check?
Thanks,
Robert
Aug 29, 2009 at 7:27 AM
FACTORYJACK
  • 4,159 POSTS
It is either no fluid, no pump pressure, or blockage in the line. By saying the lines are not stopped up, how did you check? If you took the line off at the pump and blew air through it, that would cover the whole system. While you have the line off at the pump, activate it. If you have no fluid pressure, either the pump intake is plugged, or the pump has failed.
Aug 30, 2009 at 4:04 AM
