2003 Cadillac Deville Wheel bearing
65,000 MILES • V8 • FWD • AUTOMATIC
RAYMILL
how do i replace the left front wheel bearing and what do i need
Jul 14, 2009 at 1:18 AM
RACEFAN966
  • 5,029 POSTS
Ok what you have is a hub assembly so it is a total replacement of the front hub. So what you do is first loosen the front axle hub nut then the wheel lug nuts. Now lift and support the car on the side that you need to replace. Now remove the wheel and the axle nut. Now remove the brake caliper and the support it with a bunge cord or something (don't let it hang by the brake line). Now remove the front brake rotor. From the the back side there are three bolts remove those then remove the hub assembly and put the new one back in reverse order. Here is a pic of what you are going to replace. Hope this helps.
https://images.2carpros.com/forum/automotive_pictures/249564_409895_1.jpg
Jul 14, 2009 at 2:59 AM
