2003 Cadillac Deville water pump
41,000 MILES • V8 • FWD • AUTOMATIC
GRANDPA CAN
Replaced the water pump and it still leaks. Is there somehwere else it could be leaking from or is there something I should have done when replacing it?
Checked the radiator and hoses.
Thank you
Feb 17, 2010 at 9:22 AM
FACTORYJACK
  • 4,159 POSTS
Are you sure it is leaking from the water pump? Did you replace or dislodge the o-ring seal that seals the front of the pump(pulley side). The housing, or crossover, could be leaking. That usually is most common on the rear though.
Feb 17, 2010 at 2:00 PM
