it keeps kicking the secondary air injection pump code?
86,000 MILES • V8 • FWD • AUTOMATIC
DIRTMAN1
I replaced the secondary air injection pump on the car. It was bad. Then i reset the code but it keeps kicking the secondary air injection pump code HELP ME. Thanks Jeff
Aug 9, 2009 at 1:15 AM
FACTORYJACK
  • 4,159 POSTS
Is it just a single pump, or dual pump system? Have you checked the maxi fuses in the underhood fuse block. Often times what will happen is the connector for the pump has been damaged by heat, and the terminals may be making poor, or no, contact. Also check the solenoid under the upper engine cover on the rear, that both the vacuum lines are still connected to it.
Aug 9, 2009 at 6:03 PM
STARR & ROBB
  • 16 POSTS
Same here, replaced secondary. Seems like it is still stuck in limp mode.
Strange though, never throwing us a code, fixed many things, o2sensor, mass air flow secondary...
Still stalling and no performance.
Aug 5, 2022 at 7:53 AM
  • 55,673 POSTS
Yep, this happens when the combination valve goes out, there are two of them so I would replace both unless you see an obvious problem. here are the instructions in the diagrams below on the location and how to change them out. For the limp mode I would service the throttle actuator.
Here is a guide:
Aug 5, 2022 at 9:41 AM
STARR & ROBB
  • 16 POSTS
Thanks, you guys. Let me get looking and I'll let you know!!
Aug 6, 2022 at 5:46 AM
STARR & ROBB
  • 16 POSTS
Thanks for the info guys, we are trying things. Strange now when we accelerate there is a bogging sound that flutters, goes down step on gas,flutters...Wonder if we need to replace maf again because we just replaced it cpl months ago....So far...
Aug 6, 2022 at 11:05 AM
  • 55,673 POSTS
Did you replace the the combination valves? These can cause performance issues as well.
Aug 7, 2022 at 2:01 AM
