2003 Cadillac Deville Oil Pressure Sending Unit
CORVETTESALLY
Engine Mechanical problem
2003 Cadillac Deville V8 Front Wheel Drive Automatic
Can't seem to get the connector attached to the new switch. There's not a lot of room to work, even though the engine is jacked up. Any suggestions?
May 16, 2010 at 2:34 PM
FACTORYJACK
  • 4,159 POSTS
If you have the sensor rotated to where the lock tab is interfereing with the mount bracket, that may be causing you some grief, rotate it to where the tab can have clearance. It is possible that you may have bent a pin over in the sensor, and that could be denying you as well. That could be difficult to see, may require a flashlight and a mirror. You can also undo the 10mm bolts that hold the oil filter adapter to the block. If you loosen them, the adapter will have a slight bit of play. You can remove them and lower the adapter as well. I often replace the sensor with the adapter out of the car, to me it is easier.
May 17, 2010 at 4:13 PM
