2003 Cadillac Deville light bulb
43,500 MILES • V8 • FWD • AUTOMATIC
CEH2400
how do i get the bulbs out over my license plate
Feb 23, 2008 at 4:14 AM
ED ARMES
  • 129 POSTS
You should be able to get to these through the inside of the trunk lid right behind the license plate area.
Open the trunk lid and press on the right side of the license plate bulb housing to detach the tab, then lower the housing and disconnect the wire connector.Rotate the holder and remove it from the housing and pull the bulb out. reverse the procedure when you are done.
Mar 8, 2008 at 3:21 PM
