2003 Cadillac Deville ignition
20,000 MILES • V8 • 4WD • AUTOMATIC
CHRWILL28
The ignition on my cadillac deville will not turn so that I can start my car. I have put my foot on the brake and turned the wheel and the switch still will not move. What could the problem be?
Sep 17, 2010 at 1:57 PM
ERNEST CLARK
  • 1,730 POSTS
First push up hard on your gear lever. Then while holding it up, turn the key.
If this works, then the shift linkage is bent somewhere. If not, then you'll probably have to change out the ignition switch.
Sep 17, 2010 at 10:51 PM
