2003 Cadillac Deville Deville Running rough at idle
93,000 MILES • V8 • FWD • AUTOMATIC
03 DEVILLE
My car is running ok while driving, but at a stop(in drive, neutral, or park) the rpm's drop and surge and at times almost feels as if it will stall. The check engine light came on and the codes stated that both banks were running too lean.
To date I have replaced, mass air flow sensor, fuel filter, all fluids, fuel injector cleaner, and have searched for vacuum leaks finding none.
Any help would be appreciated.
Thanks
Oct 23, 2010 at 6:00 AM
  • 75,988 POSTS
Lean fuel condition could be caused by one of the following below:
1.Vacuum leaks
2.EGR and PCV valve.
3.Low fuel pressure.
4.Dirty fuel injectors.
5.Mass Air Flow Sensor.
6.Oxygen Sensor.
Oct 23, 2010 at 11:53 AM
