2003 Cadillac Deville Check engine light and ruff idle
31,000 MILES • V8 • FWD • AUTOMATIC
KATHY A
My check engine light came on so i removed the gas cap and put it back on making sure it was tight. It also has a ruff idle.. I did put in gas but it is the same gas i alway use. I also had the gas and engine filer changed when i changed the oil last month.
Thanks for your help.
Jan 20, 2009 at 5:15 AM
OBXAUTOMEDIC
  • 3,718 POSTS
[quote:a9e3ce5cb1="Kathy A"]Engine Mechanical problem
2003 Cadillac Deville V8 Front Wheel Drive Automatic 31000 miles
Thanks for your help.[/quote:a9e3ce5cb1]
Hi Kathy,
Take it by your local auto zone or similar and have them pull codes for you. They will do it for free. Post codes here in forum.
Jan 20, 2009 at 5:24 AM
