2003 Cadillac Deville check coolant level
59,000 MILES • V8 • FWD • AUTOMATIC
RSCH4
Hi guys , I have a 2003 deville , the check coolant level light comes on almost 99% of the time. The coolant level is ok actually it is over the full when cold line. Sometimes it stays off for 2 or 3 days then right back to every time you start it.Bad sensor and live with it or is there an easy fix.
Aug 14, 2010 at 7:40 AM
BLUELIGHTNIN6
  • 16,542 POSTS
just bad sensor, can replace it if you want otherwise just put some black tape over the light area in cluster?
Aug 14, 2010 at 11:11 AM
