2002 Cadillac Deville SMELLS AND WHITE SMOKE
85,457 MILES • V8 • 4WD • AUTOMATIC
MRD3921
HELLO I JUST RECENTLY BROUGHT THE CAR LISTED ABOVE FROM A PRIVATE OWNER. I HAD A OIL CHANGE, CATALSYT CONVERTOR REPLACED, A BELT REPLACED (CANT THINK OF THE NAME). IN THE LAST THREE WEEKS. MY CAR SOMETIMES HAVE A SMELL IN THE MORNING AND WHEN I COME OUT IN THE MORNING THERE IS A LOT OF WHITE SOME WHILE I AM WARMING THE CAR. SHOULD I NOT TURN THE HEAT ON UNTIL MAYBE A FEW MINUTES LATER. THE SMOKE CLEARS AFTER A WHILE BUT SHOULD IT BE SO MUCH SMOKE. THERE ARE TWO PIPES IN THE BACK. SOMETIMES I SMELL THE ROTTEN EGG SMELL BUT I JUST GOT A NEW CONVERTOR. MY COMPUTER SAYS CHECK COOLANT LEVEL BUT I TOOK IT TO THE SHOP AND THEY SAID IT WAS FULL.
Oct 23, 2008 at 3:29 AM
DOCFIXIT
  • 18,828 POSTS
Does engine run a little rough? if so what you have described is a headgasket failure allowing coolant into cumbustion chamber. Have car checked for this.
Oct 23, 2008 at 4:27 AM
