2002 Cadillac Deville Service Engine Soon Light - Transmiss
46,888 MILES • V8 • 2WD • AUTOMATIC
LBRABOYD
A GM dealership and an independent repair garage both told me that I need torque converter rebuild. One tells me $1,800 for a temporary repair and the other tells me$3,000 for a full repair.
DTC P0741 TCC Slip speed
I cannot detect anything wrong with the transmission except for the light, however, the independent said he ran SCAN and Road Test.
I am reluctant to replace the troque converter at either price. GM appears to have had moderate problems with the transmission in this year Deville.
What do you think will happen if I just disregard this light and maintenance suggestions?
Can I drive it and be able to tell if it gets worse?
Will heat up of tranmission show on the dash indicator panel?
Wjat if I drive it until it drops?
E-mail of Call me at 405-701-1354.
Richard Boyd
Norman, Oklahoma
Oct 13, 2008 at 12:54 PM
JAMES W.
  • 2,394 POSTS
What is supposed to be wrong with the torque convertor? Is it "locking up"?
Oct 13, 2008 at 1:30 PM
LBRABOYD
[quote:ce50986b10="James R. Weizel"]What is supposed to be wrong with the torque convertor? Is it "locking up"?[/quote:ce50986b10]
They allege possible slipping. I cannot feel it.
Oct 13, 2008 at 2:52 PM
RACEFAN966
  • 5,029 POSTS
To directly answer you questions yes you can drive it till it gets worse and you will probable notice itas it does. Heat up the trans probable will not show up on the dash. If you drive it till it drops then you might have to replace the transmission rather then have it rebuilt and it may let you down on the road. Hope this helps.
Oct 13, 2008 at 3:16 PM
JAMES W.
  • 2,394 POSTS
You wouldn't be able to feel the convertor lock up 'cause it usually does it when the trasmissiom shifts into overdrive. What code(s) did your independant say you had? Also, with only 47K miles on the car, I find it extremely hard to believe the convertor is bad. Let me know on the code(s).
Oct 13, 2008 at 3:29 PM
LBRABOYD
[quote:f7b3ab5967="James R. Weizel"]You wouldn't be able to feel the convertor lock up 'cause it usually does it when the trasmissiom shifts into overdrive. What code(s) did your independant say you had? Also, with only 47K miles on the car, I find it extremely hard to believe the convertor is bad. Let me know on the code(s).[/quote:f7b3ab5967]
Boyd writes:
The code is PO741. Why the difference in prices? i.e. $1,800 to do just the TC and $3000 to do TC and updates for a permanent fix.
Oct 14, 2008 at 6:52 AM
JAMES W.
  • 2,394 POSTS
I would guess the $1800 job, which seems a little stiff to me, is a new or rebuilt TC. The $3000 job, guessing again, would be a TC and vertually a rebuilt transmission.
Have you tried clearing this code to see if it comes back? If yes, roughly how long does it take to return?
Oct 14, 2008 at 9:57 AM
LBRABOYD
[quote:c4e253a489="James R. Weizel"]I would guess the $1800 job, which seems a little stiff to me, is a new or rebuilt TC. The $3000 job, guessing again, would be a TC and vertually a rebuilt transmission.
Have you tried clearing this code to see if it comes back? If yes, roughly how long does it take to return?[/quote:c4e253a489]
No - I will try that tomorrow and let you know. That may take a few days. But thanks for the suggestion.
Oct 14, 2008 at 2:14 PM
JAMES W.
  • 2,394 POSTS
I'll wait til' I hear back, no rush, Jim
Oct 15, 2008 at 10:36 PM
