2002 Cadillac Deville replacing power Steering pressure hos
91,000 MILES • V8 • 2WD • AUTOMATIC
PAPI 305
I am trying to replace my power steering pressure hose. I traced the line from the pump but I can't seem to locate where it connects to the rack and pinion. Also are there 2 lines for each wheel? thanks
Jun 16, 2009 at 5:07 AM
FACTORYJACK
  • 4,159 POSTS
The line heads down, curves and follows the frame to where the steering shaft connects. The return line goes around the front, following the frame, and connects in the same place. 18mm is the size of both line fittings at gear.
Jun 16, 2009 at 4:07 PM
