2002 Cadillac Deville Rear main oil seal
LARRYUNC
Engine problem
2002 Cadillac Deville V8 Front Wheel Drive 103000 miles
I have a 2002 Cadillac Deville that is in excellent shape. Interior and exterior extremely clean, runs good, and rides well. Over the past several months I have had a slight oil leak from the rear main seal that has gotten progressively worse. The car uses some oil (understand that most Cad this model do) but I think it is probably leaking more now than using it. I'm debating fixing it vs. trading it. What estimated cost am I looking at to fix it. Seems hard to trade it since it is probably more valuable to me to fix and drive than what I would get out of it to trade it. Your information and advice would be appreciated.
Dec 31, 2007 at 4:48 AM
BUZZSAW
  • 1,198 POSTS
[quote:001e451aeb="larryunc"]Engine problem
I have a 2002 Cadillac Deville that is in excellent shape. Interior and exterior extremely clean, runs good, and rides well. Over the past several months I have had a slight oil leak from the rear main seal that has gotten progressively worse. The car uses some oil (understand that most Cad this model do) but I think it is probably leaking more now than using it. I'm debating fixing it vs. trading it. What estimated cost am I looking at to fix it. Seems hard to trade it since it is probably more valuable to me to fix and drive than what I would get out of it to trade it. Your information and advice would be appreciated.[/quote:001e451aeb]
its prob the oil pan leaking, never seen one leak real bad, how much oil is it using? I would say you need to have the piston rings treated, due to carbon, the oil rings stick causing oil usage. Caddlac can do this with chemicals
Jan 5, 2008 at 7:13 AM
