2002 Cadillac Deville Oil pan leak
102,000 MILES • V8 • FWD • AUTOMATIC
LPOLITE
I have a small oil pan leak. I understand the tran have to be remove to replace the gasket. Is there something I can put in the engine to stop the leak?
Jun 24, 2010 at 2:36 PM
  • 75,988 POSTS
You can try some sort of a stop leak or if you can see the leak where its coming from and you can get to the pan bolt, try tightening the bolt and see what happens
Jun 24, 2010 at 6:46 PM
