2002 Cadillac Deville fluttering during idle
115,000 MILES • V8 • 2WD • AUTOMATIC
HEATH SMITH
my car flutters/studders during idling while at a stop. It has cut-off but will crank right back up. I was told it may be the spark plugs. whatever the probelm is it does not produce an indicator light or message
Feb 12, 2008 at 2:53 AM
BUZZSAW
  • 1,198 POSTS
[quote:245b814dda="Heath Smith"]Other Category problem
2002 Cadillac Deville V8 Two Wheel Drive Automatic 115000 miles
my car flutters/studders during idling while at a stop. It has cut-off but will crank right back up. I was told it may be the spark plugs. whatever the probelm is it does not produce an indicator light or message[/quote:245b814dda]
still ck it for codes, sounds like crank sensors, or coil packs and wire boots, to get the codes: push off and down on the mode button, with key in the on position
Feb 15, 2008 at 8:33 AM
