2002 Cadillac Deville Engine Trouble
DMCFARLA
  • 2002 CADILLAC DEVILLE
  • V8
  • FWD
  • 124,000 MILES
A few months ago my 2002 cadillac deville started burning oil alot, and it keeps failing emission. About a month the radiator hose broke and I had it fixed, now the engine is runnig hot, the car is leaking antifreeze and there is no heat inside, the car runs but we have to keep putting water and antifreeze in it before we get to our destination. When it does run hot I hear like a boiling sound and sometimes see a blueish smoke coming from the tailpipe. What do you think the problem could be?
Tuesday, December 9th, 2008 AT 10:51 AM
HEYWILD_301
I had the same problem with my other 96 deville. I did and seen everything you mentioned. The problem was the thermostat. You'll need to buy a new one. I don't know how much it'll cost at a shop as I got a friend to fix it, but I am pretty sure that is what you need. Good luck to you.
Monday, June 29th, 2009 AT 8:55 AM
