2002 Cadillac Deville BRAKE, ABS, TRACTION CONTROL PANEL LI
140,000 MILES • V8 • FWD • AUTOMATIC
GMAN2002
After clearing All Codes, the Service Engine light went off, but the remaining three lights will not clear. What do I do?
Jun 16, 2009 at 9:52 AM
FACTORYJACK
  • 4,159 POSTS
Diagnose the ABS fault. If you can clear the codes, you should be also able to read the codes. If you can provide an ABS fault code(C0XXX), then we should be able to provide some assistance. Reference that last conversation we had in regards to clearing them, the same procedures apply.
Jun 16, 2009 at 4:14 PM
