What is the name of the part that controls the air flow for a/c and heat inside the car under the dash
Jul 26, 2010 at 1:55 PM
FACTORYJACK
✓Experienced Mechanic
To control the mode(defrost/bi-level/vent), or the temperature?
Jul 27, 2010 at 5:11 PM
JJMOE
MEMBER
I now know it is the mode door actuator. the problem i have now is were under the dash is it. And how do i replace it.
Aug 2, 2010 at 3:29 PM
FACTORYJACK
It is showing removal of the instrument panel carrier, which is the entire instrument panel. However, I dont know if that is the case. It is located next to the left temp actuator, which I believe is visible under the left side of the instrument panel. You may have to remove the insulator.
