2002 Cadillac Deville
90,000 MILES • V8 • FWD • AUTOMATIC
M.L.J.
Hello, i have a 2002 Cadillac DeVille , 90,000 miles and was wanting to know what are the symptoms of an clutch housing leak? My transmission runs fine. Also i know to check transmission fluid when hot but i checked it cold and theres was nothing on the dip stick. I was under the impression there should still be some kind of fluid on it even when cold? I drove it to get some more transmission fluid and i checked it right before i went in to the store and it was full almost to the top with fluid. I looked in it and it was almost to the cap and was wondering if it is safe to drive for a long trip? Thank You very much.
Mar 30, 2009 at 4:30 PM
FACTORYJACK
  • 4,159 POSTS
If the bushing in the third clutch housing is worn, your symptom would be an external leak at the left(drivers) side axle seal. Often times a seal is recommended as a repair, and it repeats leaking fluid shortly after. There should have been fluid on the stick, even when cold. You should notice on the stick, a cold range, and a hot range. I would assume that when you checked it at the store it was still running, in park? If you have no other driveability symptoms, or a check engine light, it should be fine for a trip.
Mar 31, 2009 at 5:36 PM
M.L.J.
Thank You for the reply. well i checked it again and looked in the fill hole and i see absolutley nothing in it or on the dip stick. when its hot its almost over flowing. I dont have any external leaks. no check engin lights info states transmission fluid life is at 100%.
i just wanted to see if anyone on here can give me some info. i took it to the cadillac dealer ship and they said it was a third clutch housing leak but i thought they were blowing smoke up my butt . i also went to someone i know who does a little work on cars but not a lot and he said that the leak they speak of would be an internal leak??? so i dont know who to go by as i have had very bad experiences with dealerships ripoffs (3k to fix they quoted) and other mechanics. Thank you in advance for any info out there great motor heads.
M.L.
P.S
i will try n get a picture up of the transmission fill hole when cold and then when hot. i just dont know what to think if its normal or a disaster waiting to happen.
Apr 1, 2009 at 10:06 AM
