2001 Cadillac Deville OBDII ABS Code C1235
63,000 MILES • V8 • FWD • AUTOMATIC
KB6565
Using the onboard diagnostic system, I get the code C1235 in the ABS system.
Would this code indicate that a sensor needs replacing and if so, how big a job is it?
Oct 31, 2008 at 10:52 AM
RACEFAN966
  • 5,029 POSTS
This is Right Rear Speed sensor. That is passenger side. You can do this as you will replace the whole hub assemble in order to replace the sensor. If you can remove the wheel the caliper and the rotor then you are most of the way there. Here is what you replace.
https://images.2carpros.com/forum/automotive_pictures/249564_90074_1.jpg
Oct 31, 2008 at 5:21 PM
KB6565
In researching my problem, I''ve read in 2 different forums that the whole wheel bearing hub assembly ($112.79 ) has to be replaced. In another I've read that the sensor itself can be replaced and is available from RockAuto (AIRTEX Part # 5S4644 - $34.79). Can someone tell me definitively which is correct. Could this just be a bad connection?
https://images.2carpros.com/forum/automotive_pictures/264558_Rear_Wheel_Speed_Sensor_1.jpg
Nov 16, 2008 at 11:15 PM
RACEFAN966
  • 5,029 POSTS
It is a hub assembly replacement and yes it could be a bad connection but not likely. Thanks
Nov 17, 2008 at 4:14 AM
