2001 Cadillac Deville message center
91,000 MILES • V8 • 2WD • AUTOMATIC
ALLSEE
My message center tells me to check engine coolant but the recovery tank is full. Heater doesn't seem to be working correctly but engine does not overheat.
Any suggestions?
Feb 24, 2010 at 8:06 AM
FACTORYJACK
  • 4,159 POSTS
If your coolant level light is on, and the reservoir is full, then the sensor in the reservoir is faulty. You can disconnect it on the bottom side of the reservoir and the light should go out. The sensor is part of the reservoir.
Feb 24, 2010 at 4:20 PM
