loping idle lean fuel mix on left bank & right bank?
75,000 MILES • V8 • FWD • AUTOMATIC
FRANK HERDMAN
trouble code lean fuel mix on left bank & right bank. have replaced iac valve & tp sensor. also has a loping idle. replaced all 3 oxygen sensors, pcv valve & spark plugs. still have loping idle. idle rpms are 575-650. vacuum psi 19 steady.
Dec 12, 2007 at 11:38 AM
BLACKOP555
  • 10,386 POSTS
the lean bank code usually means a bad O2 sensor, replace and your problem shoudl go away.
can you provide with the codes?
Dec 12, 2007 at 12:23 PM
  • 55,746 POSTS
I don't think so, it sounds like the fuel pump is going out or the fuel filter needs to be replaced, here is the location of the fuel filter and a guide to help you understand what the problem is.
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
Fuel pressure should be
Key On Engine Off 41-47 psi
Check out the images (below). Let us know how it goes.
Aug 27, 2024 at 7:01 AM
