2001 Cadillac Deville coolant drain and thermostat location
2001 CADILLAC DEVILLE
102,000 MILES • V8 • 2WD • AUTOMATIC
RECOVERYM88
I am currently working on a Deville and was wondering where in the world is the drain for the radiator and the location of the thermostat. I have a good idea but don't want to mess this up. Please help thank you
Mar 22, 2009 at 2:58 PM
FACTORYJACK
  • 4,159 POSTS
Drain is on the drivers side front of the radiator tank, you can see it through the front grille area of the bumper fascia. 19mm socket fits on it, there is a hole in the lower splash shield for access, I just remove the shield to minimize the mess. Follow the lower hose to the water pump cover, that black housing that is bolted on is the T-stat housing.
Mar 30, 2009 at 3:09 PM
