2001 Cadillac Deville check engine light on
121,000 MILES • V8 • FWD • AUTOMATIC
RICHPAS
I had codes pulled. Said it was the cam sensor and crank sensor. Car still operates just idles rough. They were trying to tell me it is a wire harness. I suspect sensor or connection.
Apr 21, 2009 at 6:39 AM
FACTORYJACK
  • 4,159 POSTS
Is the only symptoms rough idle? Is it stalling, or experiencing long crank times? What were the codes p0335, p0385, p1376? Crank sensors have been a problem, especally in those years. If they can tell you which code triggered the light, my guess is p0335, or p0385, have the crank sensors replaced and a crank variation relearn performed.
Apr 21, 2009 at 4:11 PM
