2001 Cadillac Deville V8 Wheel Drive Type unknown Automatic 106063 miles
What is it when your car will only stay Crank if your foot is on the gas but as soon as you take your foot off the car cuts off
Monday, March 31st, 2008 AT 8:18 AM
BLACKOP555
MECHANIC
Is your idle speed set high enough? If you unplug the IAC module and start it does that fix the problem?
Monday, March 31st, 2008 AT 8:24 PM
BUZZSAW
MECHANIC
It doesnt have an IAC, pull your codes, off and down on the mode button on the heater controls at the same time, with the key in the on position, write them down and post them here! Look at the message center for the codes
