2001 Cadillac Deville Cadillac wont start
ALEX TAMBURRI
Engine Performance problem
2001 Cadillac Deville V8 Front Wheel Drive Automatic
This deville came to us as a will not start. The computer had several codes, CPS sensor A circuit problem CPS sensor B Cam sensor pcm memory loss generator lamp control circuit problem. Starting with the first code CPS A did not fix problem.
Sep 12, 2008 at 12:03 AM
2CARPRO JACK
  • 11,533 POSTS
I would need the code numbers to look then up, but if it is giving both crank and a cam sensor code, it could be a PCM problem.
Sep 13, 2008 at 12:56 AM
