2001 Cadillac Deville abs light is on
140,000 MILES • V8 • FWD • AUTOMATIC
JUNIEJUN49
my abs lights is on with the brake light and traction light the fluid is at the right level in the reservoir how can i fix this
Apr 24, 2010 at 4:19 AM
FACTORYJACK
  • 4,159 POSTS
Press info up, and on/off at the same time and hold until all the segments light up. It will display ALL?, press info button either up or down to find ABS?, and then press on/off. It should display ABS CODES?, if it don't use the info button until it does and press on/off. Record the codes and post them.
Apr 26, 2010 at 5:00 PM
