2001 Cadillac Deville 2001 cadillac deville making noise wh
112,582 MILES • V8 • FWD • AUTOMATIC
624871FT
this car has been a pain in the neck for me . this car makes a licking noise only when i turn to the right
ive already changed hubbearings , cv axles . so can anyone give me a hand with this dang cadillac
Feb 28, 2008 at 3:09 PM
ED ARMES
  • 129 POSTS
When the strut bearing ( on top of the strut ) goes bad it will make a clicking, popping or cracking sound as you turn the wheel. Does this sound like what is happening?
Mar 8, 2008 at 3:02 PM
624871FT
yes it does thanks for the info
Mar 9, 2008 at 7:58 AM
ED ARMES
  • 129 POSTS
If you are into doing it yourself, the parts should be available at most autoparts store. I have replaced these in foreign and domestic vehicles with same symptoms. Not super easy to pull strut assembly but not technical either. Everythings metric.
Mar 9, 2008 at 8:33 AM
BUZZSAW
  • 1,198 POSTS
[quote:0c77f1a5d0="Ed Armes"]If you are into doing it yourself, the parts should be available at most autoparts store. I have replaced these in foreign and domestic vehicles with same symptoms. Not super easy to pull strut assembly but not technical either. Everythings metric.[/quote:0c77f1a5d0]
you will also need an alignment, a spring compressor, and the bearing only goes on 1 way
Ed good job on this 1
Mar 10, 2008 at 6:04 AM
