2000 sedan deville 100,000 miles
CONDEN
Crunching sound like crushing can when turning at 10 mph or lower. STRUTS WERE REPLACED about 20,000 miles ago.
Also, have whizzing sound at 30 - 50 mph from right side under hood. sort of sounds like low tire road noise,but isn't. Steady sound. does not get loader or less when speeding up or down.
Aug 3, 2007 at 1:57 PM
  • 75,988 POSTS
[quote:ecf40c985c="trappnman"]89 F-150
starts right up cold, as long as its short trips, continues to start right up. Anything over 1/2 hour, it barely turns over. let sit 1/2 hour, and it starts right up, fast starter spin.
I checked and cleaned all connections, new battery from last spring (know its good), relaced both postive and negatoive battery bcables, and replaced starter.
My starter tested bad, got a rebuilt NAPA one, it was junk from the "start", so replaced that yesterday- still same problem.
will pop right off if parked on slight incline and rolled 10 feet. (manual)
I think timing is good enough- but could be- but keep coming back to the starter is bad once again.
Could it be the coil? When I've had a coil go out, it makes the engine miss, and the engine runs great once started (full power, etc which leads me to bleieve timing is off)
but could coil cause hard starting when hot?
I'm about to take that starter back again.
Help please![/quote:ecf40c985c]
but could coil cause hard starting when hot? Yup, if it looses its ability to build the magnetic field required for the secondary circuit in the ignition system
Are you overheating above that 1/2 hr
Recheck the ignition timing it will do that if its off-makes it look like something is wrong with the battery/starter.
Aug 3, 2007 at 3:28 PM
TRAPPNMAN
thanks for the reply
yes, it continues hard starting. I use vehicle on farm, and it continues with the problem after it gets hot. Once it cools down, then if I start and shut it off on continous short times, it starts ok
Aug 3, 2007 at 3:46 PM
  • 75,988 POSTS
[quote:49a64a908d="trappnman"]thanks for the reply
yes, it continues hard starting. I use vehicle on farm, and it continues with the problem after it gets hot. Once it cools down, then if I start and shut it off on continous short times, it starts ok[/quote:49a64a908d]
My next suggestion is try checking the fuel pressure with a fuel pressure gauge to see what the pump is doing could be failing to include the fuel pump relay or the inertia switch.
Aug 3, 2007 at 5:15 PM
