also car uses abuot 1 quart of oil per 1000 miles, I have been told by dealer this is normal for a Northstar, is this corrrect?? (i change oil every 3000 miles)
Thanks for your help!
When the lights appear, press Off and Warmer together on the climate controls to display diagnostic codes, then diagnose those faults rather than only clearing them. Oil use of about one quart per 1,000 miles is excessive; check for leaks versus burning, and have a Cadillac dealer evaluate carbon-stuck piston rings and a chemical treatment if it is burning oil.
The owner of a 2000 Cadillac Deville DTS reports intermittent Service Stability System and Service Security System lights that dealers could not reproduce after clearing codes, plus oil use of about one quart per 1,000 miles. Experts say the lights cannot be permanently reset without identifying the fault and request the codes, which can be displayed by pressing Off and Warmer together. They also say the oil consumption is not normal, may result from leaks or burning, and that carbon holding the piston rings may be treatable chemically by a Cadillac dealer.
