2000 Cadillac Deville Rear Main Seal
138,345 MILES • V8 • 2WD • AUTOMATIC
WHEELER90
How do you change a rear main seal on a 2000 Deville?
Dec 26, 2007 at 1:11 PM
BUZZSAW
  • 1,198 POSTS
[quote:3ee2870bc7="wheeler90"]Other Category problem
2000 Cadillac Deville V8 Two Wheel Drive Automatic 138345 miles
How do you change a rear main seal on a 2000 Deville?[/quote:3ee2870bc7]
this is a huge job, and the trans needs to come out, and the engine suspended in the car with a engine support, and do the oil pan gasket as well, 12-1500 at dealer, took me a day and a half to repair this, so this is not for the non-mechanical person
Dec 28, 2007 at 6:53 AM
WHEELER90
[quote:bc80ba46e9="Buzzsaw"][quote:bc80ba46e9="wheeler90"]Other Category problem
How do you change a rear main seal on a 2000 Deville?[/quote:bc80ba46e9]
this is a huge job, and the trans needs to come out, and the engine suspended in the car with a engine support, and do the oil pan gasket as well, 12-1500 at dealer, took me a day and a half to repair this, so this is not for the non-mechanical person[/quote:bc80ba46e9]
This helps a-lot I have been hearing things of a special tool needed to remove pins from the tranny to get to the seal. Is there any validity to that if not I will have some help from a good friend who know a little more than about Cadillacs. Thanks for the info if you have any thing that may be helpful please send it.
Dec 29, 2007 at 3:10 AM
BUZZSAW
  • 1,198 POSTS
[quote:bbb647d8cd="wheeler90"][quote:bbb647d8cd="Buzzsaw"][quote:bbb647d8cd="wheeler90"]Other Category problem
How do you change a rear main seal on a 2000 Deville?[/quote:bbb647d8cd]
this is a huge job, and the trans needs to come out, and the engine suspended in the car with a engine support, and do the oil pan gasket as well, 12-1500 at dealer, took me a day and a half to repair this, so this is not for the non-mechanical person[/quote:bbb647d8cd]
This helps a-lot I have been hearing things of a special tool needed to remove pins from the tranny to get to the seal. Is there any validity to that if not I will have some help from a good friend who know a little more than about Cadillacs. Thanks for the info if you have any thing that may be helpful please send it.[/quote:bbb647d8cd]
its probally the oil pan thats leaking, you need an engine support and trany jack, air compressor ( to remove the frt pully bolt, its tough), frt pully puller, you have to use a special sealer for the oil pan, do both pans, parts are about 500.00, you have to drop the engine down about 7-10 in to get the trans out
Jan 5, 2008 at 7:26 AM
