2000 Cadillac Deville Passenger side rear power window ceas
85,000 MILES • V8 • 2WD • AUTOMATIC
JBROWNING
power window ceased working on the passenger side rear in the down position.
Apr 24, 2009 at 3:26 AM
CPR
poss problem window regulator cable has broken
not allowing window to roll back if you remove panel you can see broken cable the cable it self can not be replace and the regulator will have to be
Apr 25, 2009 at 6:54 AM
