2000 Cadillac Deville oil level
65,000 MILES • V8 • 2WD • AUTOMATIC
YOUMANYO
The oil dipstick shows there is no oil and the low oil level comes on , but there is plenty of oil in the car. The reason I know this is I drained it and it was full.
Mar 16, 2008 at 2:20 PM
ED ARMES
  • 129 POSTS
Takes a minium of 7 1/2 quarts of oil to fill. Typically is 2 quarts low when it drops off of stick.
Mar 16, 2008 at 3:34 PM
BUZZSAW
  • 1,198 POSTS
[quote:c27e1ee49a="youmanyo"]Engine Mechanical problem
2000 Cadillac Deville V8 Two Wheel Drive Automatic 65000 miles
The oil dipstick shows there is no oil and the low oil level comes on , but there is plenty of oil in the car. The reason I know this is I drained it and it was full.[/quote:c27e1ee49a]
when you drain it and fill it it holds 8 qts with the oil filter. If lite is still on change the oil level sensor its down by the crank sensors, by the frt motor mount
Mar 16, 2008 at 8:16 PM
YOUMANYO
I did not no it took 8 quarts, I had only put 5 in ,duh.
Thank you
Mar 17, 2008 at 11:15 AM
ED ARMES
  • 129 POSTS
Sometimes the simpliest information is the best.
Mar 17, 2008 at 11:53 AM
YOUMANYO
I put in the 8 quarts and the light is still coming on , is changing the senser a hard job ?
Mar 17, 2008 at 1:13 PM
BUZZSAW
  • 1,198 POSTS
[quote:bc4a196167="youmanyo"]I put in the 8 quarts and the light is still coming on , is changing the senser a hard job ?[/quote:bc4a196167]
no, 1, 10 mm bolt, the sensor is about 4 inches long, the crank sensors are together, to the right of them is the oil sensor
Mar 18, 2008 at 5:16 AM
