2000 Cadillac Deville Key wont turn in ignition
68,200 MILES • V8 • FWD • AUTOMATIC
LED62ZEP
The key would not turn in my 2000 Cadillac Deville. After several times at trying and turning the wheel left and right while turning key...it finally turned. What is the problem?
Apr 6, 2008 at 1:22 PM
BLACKOP555
  • 10,386 POSTS
does it turn good now, was the steering wheel locked though when you tryed to turn the key?
Apr 6, 2008 at 2:13 PM
BLACKOP555
  • 10,386 POSTS
replyed in pm
"Sir,
Sometimes it does. Sometimes it doesn't. Yes, the wheel was locked at the time. But, it does do it frequently, more times than not. Just started doing it today."
Apr 7, 2008 at 12:11 AM
JOSEPH RUIZ
  • 9 POSTS
i had the same trouble with my 89 deville, and the locksmith cured it with simply shooting a little lubricant into the key cylinder.it was called tri-flow superior lubricant.try that!!
Apr 7, 2008 at 10:27 AM
BLACKOP555
  • 10,386 POSTS
just replyed to your email sir. follow my diirections on there.
and yes joseph, that stuff works really well and it usually only requires lubrication, better then replacing the cylinder!
Apr 7, 2008 at 11:42 AM
