2000 Cadillac Deville DHS... Changed out fuel rack... Began to idle high after replacement.
Jan 19, 2010 at 4:55 PM
FACTORYJACK
✓Experienced Mechanic
More than likely, you have a vacuum leak. If it was an injector O-ring, you would have misfire. I would check that the boot between the intake and throttle housing is not split.
