2000 Cadillac Deville i need help
150,000 MILES • V8 • FWD • AUTOMATIC
TJSDADDY
ok i have a 2000 deville with 150,000 thousand miles when i drive it down the road the check engine light will come on and flash when i scan it it throws up code p0300 wich is random misfire but it goes away and runs fine it doesnt do it all the time only every so offten i have replaced both coil packs wit oem parts from cadillac but now im at a stand still please help with any info thanks james
Dec 8, 2007 at 11:02 AM
BUZZSAW
  • 1,198 POSTS
[quote:19f3de10ce="tjsdaddy"]Engine problem
2000 Cadillac Deville V8 Front Wheel Drive Automatic 150000 miles
ok i have a 2000 deville with 150,000 thousand miles when i drive it down the road the check engine light will come on and flash when i scan it it throws up code p0300 wich is random misfire but it goes away and runs fine it doesnt do it all the time only every so offten i have replaced both coil packs wit oem parts from cadillac but now im at a stand still please help with any info thanks james[/quote:19f3de10ce]
did you get new spark plug boots with the coil packs?
Dec 10, 2007 at 4:39 AM
