2000 Cadillac Deville Headlights and Key in ignition
109,400 MILES • V8 • FWD • AUTOMATIC
RANGER2183
I have a 2000 cadillac deville, and just recently, whenever I turn off the car, and open the door, the "ding" alarm for when the key is still in the ignition goes off, even when the key is not in the ignition.
Also, my headlights stay on constantly, even during the day, instead of my daytime running lights. I appreciate any assistance, thank you.
-Alex
Aug 4, 2010 at 12:51 PM
FACTORYJACK
  • 4,159 POSTS
Is the alarm perhaps to let you know that the headlights are on?
On the headlights, if the twilight slider is all the way to the left, and the manual headlamp switch is off, are the lights still on. If not does it say headlamps suggested all the time on the info center?
Aug 4, 2010 at 4:02 PM
RANGER2183
I'm not sure about the noise, but there is no headlamps suggested in the info center, like there usually is when you turn them off, but they do not turn off unless I actually rotate the headlamp knob next to it to the off position
Aug 4, 2010 at 11:24 PM
FACTORYJACK
  • 4,159 POSTS
If you are rotating to off, to turn them off, then they are manually turned on and will not go off. You should be able to leave the manual knob(the rotating one) in the off position, and use the slider just below it for automatic operation. The more the slider is to the right, the longer they stay on after key off. The chime is indicating that the lights are manually overridden to the on position. With the slider all the way to the left, and the manual knob set to off, you should get a headlamps suggested message that displays in low light conditions.
Aug 5, 2010 at 2:56 PM
